Increment revision history manually
I am using LV7.
How do I control the increments of revision history. It seems to increment it by 1 everytime I save.
(3,226 Views)
RJay wrote:
> I am using LV7.
You can't really change the revision history version other than
resetting it to 0.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,226 Views)
Yes..
I noticed that..
(3,226 Views)
I suppose, when thinking logically, if you wish to set the version to X, you could set the version to 0 (Saving in a new file) and then save it X times.
I know it's a bit stupid, but hey, why not?
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,226 Views)
Hi!
Take a note, that you can reset revision number to zero programmatically, and then set to appropriate value (over property node - see attached image)
(3,226 Views)
Of course, that's not a bad idea either......
And definitely more refined.
Shane.
(3,226 Views)
Except that you lose your revision history. So BEWARE!
(3,226 Views)
