Incrementing Numeric string and timing simultaneously and displaying different lap results on 2D Array using stopwatch and labview
Greeting everyone!
 I am working on lap timing using stopwatch topic, the output should be displayed in the form of 2D array, representing first column as "ROUND_1" and second column as Lap timing. Every time the user presses the Lap button, a new Lap number and Time should be written to the 2D array.  The most current Lap should be at the top of the array. Please refer the attached file. Lap timing second column was worked, but have concatenate numerical string in first column and lap timing simultaneously. Any help will be appreciated!!
Thank in advance.
(2,103 Views)
Hi ckrdeeps,
All we got are 3 images: we cannot edit/debug images with LabVIEW…
There is no 2D array in your code. Maybe you should create such an array?
(2,096 Views)
Hi GerdW,
     Thanks for your response, BTW, I have created as array in block diagram code. it works fine with 1D array. please refer the attachment. but for 2D, we have to display output of both string and lap timing simultaneously. i am still stuck with this concept. If you don't mind, can we attach a VI code here, so that you can give your suggestion and help me! as I am new member, still I did not know about this!
(2,077 Views)
Hi ckrdeeps,
You cannot mix datatypes in an array, all elements need to be of same datatype.
Use a 2D array of strings…
Sure you can attach VIs here, but you still just attached some JPG images…
(Btw. using JPG for LabVIEW code images is creating blurry images. Use PNG as image format instead!)
(2,064 Views)
