Incrementing a GPIB parameter in Labview
Hi
I an trying to product a program in labview that increaments a GPIB command
to a Function Generator.
The command format is: FRQ 1.0E + 2 (this equals 100Hz). I need to
increament this up 1MHz so,
I have written a bit of psudo code to demonstrate what I require.
For i = 1Hz to 1MHz
// Send freq requ. to function gen //
FRQ i
//QUERY Function Gen to ensure freq has been changed =Q //
If Q=FRQ then Next
else
Print "Error: out of sync!"
Stop
Regards
Wayne Lawson
(2,822 Views)
In my sample VI, you might need to change your "query command to query the frequency of the generator". I assume the step size is 100Hz. If you cannot get the data from generator, try to increase the bit count in VISA read. Good Luck.
When you feel sad, laugh
(2,822 Views)
