I have a piece of code that I am using to:
1. create a bitmap file 100 x 100px,
2. open the bitmap file
3. draw a white rectangle the size of the image
4. draw a black line at a set height (Line Distance - y) - in this case 10.
What I would like it to do is to loop through for as many times it will fit in the image (e.g. 20, 30, 40, etc.) until it reaches the end of the image. I just cant see how to edit or increment the value in the cluster?
Also, is it possible to link the 'y' value on both 'Line Distance' and 'end point'? Is it possible to link the 'x' value on end point to the right side of the image? I was trying to bundle and unbundle with no success.
I've highlighted the section I believe should be looped but without being able to change the values I'm lost!
Aidan
(2,498 Views)
Hi Aidan
Apologies in advance if  I have got the wrong end of the stick, but is this what you are after?
Or using Bundle and Unbundle By Name
Steve
(2,488 Views)
Hi Aidan,
Yes.
Yes.
What exactly have you tried?
Yes.
Added a loop using a shift register to store the image, added BundleByName to change point inputs for both draw functions…
(2,485 Views)
