Independent color control using XY graph
We are using XY-graph to make multiple simultaneous plots -- each plot being a cluster in an array of clusters -- and we would like to independently control each plot's color. Currently, the order of the cluster in the array determines the color of the plot (white first, red second, and so on).
Thanks, Robert
(2,576 Views)
Use the active plot and Plot.color in property node.
(2,577 Views)
Thanks for the code and comment, unclebump. I will give it a shot.
Robert
(2,546 Views)
