Independently control two audio channel volumes
I am trying to independently control the volume two channels of audio output. I have specified that I want two channels using SoundOutputConfigure.vi and I am giving SoundOutputSetVolume.vi an array of two volumes. Unfortunately, this results in the volume for both channels being set to the value of the first element in the array. What am I doing wrong? I am running LabView 2012 64 bit on 64 bit Windows 7.
(2,993 Views)
Hi Adam,
Have you seen the examples for using sound VIs? You can find them by going to Help >> Find Examples. Then within the Example Finder, go to Hardware Input and Output >> Sound. A good example to look at would be the Generate Sound.vi. Take a look at this example and other examples within the Sound folder. These are good references to compare to your current code. Good luck!
Rita Prather
Software Product Manager
rita.prather@ni.com
(2,938 Views)
