Index Array
Spoiler
Howdy,
So I have an Excel file with 2 columns of data and I'm trying to separate it into 1D arrays using the Index Array function. I have the data going to 2 index arrays with one set to index column 0 and the other set to index column 1. I recorded the data after each index just to see what I was getting. The column 0 array is the only one that I get as an output, the column 1 output is blank. Any ideas what's going on?
(1,192 Views)
You can use a single "index array" node, drag down from the bottom to get more outputs.
You must not be reading in the Excel file the way you intended. If you attached your code here we could give you more advice.
Are you using the Report Generation Toolkit to read from the Excel file? Is it really an Excel file (.xls or .xlsx), or a generic spreadsheet like comma or tab separated values?
(1,180 Views)
