Index array from boolean-triggered event
Hello fine people of the interwebs,
I am in a bit of a pickle. I have a boolean triggered image analysis that retruns a measurement. I would like to store the result each time the process is triggered in an array, up to 6 elements. The process would overwrite measurements  sequentially, until another process is triggered to write the data for storage and clear the array.   I have uploaded a rough example of what i am trying to achieve (minus the data storage routine). Any help would be greatly appreciated
(3,194 Views)
Accepted by topic author coolmatt2112
Sounds like you are going for something like this...
(3,178 Views)
Thank you so much for your help! This was a very instructive example.
(3,141 Views)
