Index array of a cluster
Ouch! Who wrote that code? This needs to be rewritten from scratch, because it is full of glaring programming mistakes.
Sorry, I cannot help you at this time.
(See also here)
Message 11 of 23
(35,094 Views)
@NewerProductionDeveloper wrote:
I had to remove the server connection data.
VI is attached...
Can't even open the VI.
Remember that not everybody has the newest LabVIEW.
Message 12 of 23
(35,077 Views)
It's for the best.
This is not a text based language, you don't need to init variables.  Even if you did you don't need to re-init them every iteration.  Also the wires are the variables, not the controls.
Never seen a 7 point font on a front panel before.
Using a while loop as a for loop.
Okay so you have no way of stopping your program, you have a false wired to stop, so your program either runs for all eternity, or you stop your program like you stop your car, by crashing it into a tree
In case 4 of 8 in the top level sequence, you have two while loops, and the stop from one goes to the stop of the other, this means the second while loop will never execute more than once.  Just remove it, it does nothing for you.
You are missing seeral VIs, they weren't attached.
Many wires go backwards.
It is generally bad practice to use sequence structures.  Stacked are hated even more than flat, and sequence variables are hated the most of all.  Try not to use them it makes debugging code very difficult.
What good is the sequence structure in side the case 6 of the sequence structure?  It does nothing for you.
Lots of locals, when shift registers could be used, like the Total Repairs.
Reading a local variable multiple times in a while and for loops when it doesn't change.
Use an event structure, it help perform actions on events like control value changes.  It can also handle things like when the user tries to close the window, which yours currently doesn't handle.
I'm not trying to rip you apart, but these are major red flags.  You'll want to go through some free training.  If you have any specific questions feel free to ask them.  I tried going back to understand if you have any remaining questions and it is unclear to me.  Do take Altenbach's advice on searching the array of clusters.
Message 13 of 23
(35,066 Views)
@Hooovahh wrote:
It's for the best.
I already listed some of the same points earlier, but there are many more.
I strongly agree with this recommendation. Obviously you are coming from a text based programming background and try to do a 1:1 translation into LabVIEW. Stop progamming now! Continuing to program at this point will only cement really bad habits and will make them much more difficult to un-learn later. Do some courses and tutorials, look at the examples and design templates that ship with LabVIEW. Learn about dataflow. Once you pass the CLAD example exams, you can go back to coding.
Message 14 of 23
(35,047 Views)
Yes I came from a text based development. I am NEW to labview, that's why my name is "NewerProductionDeveloper". I had LITERALLY 1 week worth of training on this program, and then it was tossed into my lap.
1st off, the program is NOT to stop, because they are wanting it to continually run without end. 2nd off, they haven't given me time to do any training on this, they are just wanting results. 3rd off- about the training, I have asked them to send me to classes so that I can do this BETTER. I want to learn the program because I can see a lot of potential with it in this work environment, but they have to get it approved to do so. A month later (today) and still no response.
I know that my coding SUCKS SORRY, but I am being pressured to just get results, and I am doing the best I can with the timing that they have given me. I did the 1 free training class that was given with the programming, but I was having to build the program while doing the class.
Message 15 of 23
(35,013 Views)
All of our code sucked at one point, sorry if we seem harsh.  First here is some free training, that you've probably seen, or not had time for.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
-cRIO Developer's Guide
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
I'd like to make a few comments, you say the program is not to stop.  I think we are confusing what stop means here.  Is the program supposed to exit?  Is there a time when the program should not be running on the computer?  Someone can say "Outlook should always be running".  That doesn't mean you shouldn't be allowed to close it.  Same with this application.  You actually are telling LabVIEW that this program should not be allowed to stop running and exit based on what you coded.  A better strategy is to detect when a close is requested, using the event structure and perform closing operations.  Like turn off DAQ, close log files or other various tasks.
Message 16 of 23
(34,987 Views)
Our Business Unit Leader doesn't want the programs to close "AT ALL." He has asked when I compile the program to remove ANY exit options. He had me set it up where the only way to close is CTRL+ALT+DEL.
I agree with you on stopping it at a certain point, but my boss' boss said no. lol
Message 17 of 23
(34,981 Views)
I know that my code sucks, I am just trying to let you all know where I am at on the learning of bettering it. My hands are tied, and I told them that I am not the best person for this job right now, and they go, "we believe you can take it and run with it, if given some time." Then they start pushing saying, "when, when, when."
Message 18 of 23
(34,980 Views)
This all sounds very unpleasant.  Your boss is wrong, and I would thoroughly enjoy telling him that.  Windows programs should be able to exit, with the only exception I can think, is if it is the only program running.  If there is no Explorer.exe, then I can see why your program should not be allowed to exit but in any other case, this flies in the face of standard Windows application styles.
What other standard Windows practices can we ignore?  Why should the left mouse button be used for selection?  Lets switch the right and left mouse buttons, or use those buttons for scrolling, and the middle mouse button for selection.  This is the level of crazy that some bosses go to, when they don't know what they are asking for, and are not the expert in the field where they are making decisions.  A good boss knows when to rely on the people he hired, to do their job.  And as a software developer that would be things like the design, and architecture choice.  I'm glad I'm not in your shoes.
Message 19 of 23
(34,970 Views)
I agree there should not be a stop button on the front panel, that's unusual for a typical program. Instead, you can monitor a "windows close" event, i.e. when the operator clicks the [x] in the upper right corner. At this point you can throw a confirmation dialog, initialte a defined shutdown sequence, or even ignore the close action and tell the user that something is not in a state that allows safe closing of the program at this time.
There should always be some safe defined way to close a program and there are valid reasons to do so, e.g. for computer maintenance, software updates, troubleshooting memory leaks, etc.
Message 20 of 23
(34,942 Views)
