Indicators and Controls on my GUI application move out of alignment when run on chinese windows 10.
I have a data logging application wsritten on Labwied 2012 that has been used for calibration purposes for several years throughout the world, although in low numbers less than 10. I have had no problems with the GUI until recently when a distributor from Tiawan installed it on their Laptop running Chinese windows 10 at 1366 by 768 resolutions. On my GUI I have several arrays of numerical values that normally aligned, these became offset and staggered and not asthetic at all. I have run the same software on a UK Windows 10 machine at the same resolution without any issue has anybody any ideas?
(2,975 Views)
That sounds like the typically font issue.
Did you include the font entry in the *.ini file for your exe?
You can copy them from your LabVIEW.ini
Make sure you use the font name rather than "0".
example: systemFont="Segoe UI" 13
George Zou
(2,943 Views)
