Indicators
i have to show the results of an analog data aquisition (called "ada"
next times)
on 16 indicators.
i have to configure the "ada" with high limit / low limit and analog
channels
change will change, cause the analog board will be set up with several
channels,
ranges etc. when a test has to begin.
now i want to select the specified indicator (cause of range and unit),
on which
should be diplayed the results of channel 0. and if channel 0 is e.g.
temperature
it has to be diplayed on indicator 5. if it is pressure it has to be
displayed on
indicator 4 (only as an example for explanation). the next time i run
the program
the employer has changed both inputs and select this confiduration, the
program
has to put it on the indicator i want to. my proble
m is that an
indicator can't be
moved into a subvi within a "ada" while loop. any suggestions or do u
need
more information?
regards
cRayFiSh
Message 1 of 1
(2,866 Views)
