Induction motor control using labview
Is there any innovative idea to work on induction motor using labview?. Data acquisition part is over. What can one do for controlling the induction motor using that data? Please give some suggestions if any possible.
(4,617 Views)
You haven't supplied enough information here for us to help you. Do you have a specific motor you are trying to control? If you have a device that can communicate with LabVIEW, there are a set of commands (or rules) that the communication needs to follow. If your device comes with a command list, then you can use these commands to control it with LabVIEW. What kind of communication does your device utilize? USB? RS232? RS485? TCP/IP?
Cheers
(4,557 Views)
It's a 3 phase induction motor. And I have data acquisition done using DAQ cards and LAN
(4,547 Views)
Still not enough information... How do you expect to communicate with the motor to control it?
Cheers
(4,541 Views)
