Infinium 54825A scope screen capture
Hello guys,
I have a Infinium (HP) 54825A oscilloscope that uses GPIB to communicate with labview 2010. I want to capture the screen of Infinium 54825A for each test condition. However, I don't find such kind of .vi in the NI web. And also I didn't find the command in the Infinium manual. Is anyone able to help me to generate the relevant .vi file?
Thanks.
(2,759 Views)
If you need to capture the screen of Infinium 54825A for each test condition, you would need to know the command that you can send to it. If you don’t have the command, it could be difficult to capture the screen because the communication it’s through NI-VISA and it needs commands to communicate with the hardware.
(2,703 Views)
