Inherit from GObject or control-class
 I'm getting into OOP right now. And I want to know, if the following is possible.
The basic question is: Can I (re)create a graph front panel indicator myself? If this is possible, it allows anything, I want to do.
My guess, how it works, if it is possible:
First I have to create a class, which inherits from the GObject-class or even, more specific from the control class. Then I have to design a front panel element and a method or rule, which determines how to display the data wired to the FP-Indicator.
So, in the example of the graph indicator, I have to create a "vi" which takes double arrays and "paints" them on a black background.
Is this possible in general, or does this need some deep coding with tools not available to the public?
(3,088 Views)
Accepted by topic author LabViewTinkerer
The closest I think you will get to what you want to do is using XControls. If you want a more OO approach, I have heard of the toolkit below but I have never used it myself.
https://www.ni.com/en/support/downloads/tools-network/download.qcontrol-toolkit.html
Any XControl does technically inherit from Control class in the VI Server hierarchy but I imagine you aren't getting as much control as a LabVIEW R&D dev would get making a new front panel item.
(3,078 Views)
