Initialize DMM with IVI
I'm trying to create a software session with an NI-4071 using IVI drivers. I have used MAX to point to the niDMM drivers that support the model. The resource desriptor associated with the driver is correct. The error code I get back is -1074118656. I can talk to the DMM using the software front panels in MAX. Any clues?
(2,740 Views)
E=McHammered wrote:
Any clues?
A search usually helps: Receiving Error -1074118656 when Running NI-DMM VIs.
(2,730 Views)
