Initialize NI-2548 SPDT with topology using IVI
I'm controlling a NI-2548 in labview using  IVI. What are the Topologies I enter. I know the convention for the Initialize with options string is "Topology:Model/Topology" (i.e. 2530/1-Wire 192 x 1 Matrix ). What is the topology string your enter of a SPDT, namely the NI-2548. Also, what are the parameters you enter to connect a channel in IVI?
(2,889 Views)
Hi E=McHammered,
All of this information can be found in the NI Switches Help file (Start»Programs»National Instruments»NI-Switch»Documentation).
Specifically, the Quad SPDT Topology section (under Devices»NI PXI 2548) gives and example scan list entry for connection as no1->com1, to route a signal connected to NO 1 to COM .
David
Digital Multimeters
(2,875 Views)
Accepted by topic author E=McHammered
Hey thanks but I was able to Forest Gump my way to the right solution.
(2,869 Views)
