Initializing Control Inputs to default value.
This may be a stupid question, but I am new to labview. When the VI is started I want it to read the data from the PLC(via the OPC Server)initially to set up the controls default value. Then if the user wants to change it, they can type a new vlaue.
Currently every time you start labview in clobbers the data in the PLC with its default value. I thought of using a write on change tag, but then it doesnt show what the current set point is.
Thad
(3,331 Views)
If you wanted to get the PLC values before makeing any changes to them, I would recommend using a Tag Read and update your front panel control with the use of a local variable. This would be an initialization routine.
Another possible answer to your question is that you will want to use the Options >> Make Current Values Default selection on your Front Panel. This way anytime your VI is reloaded it will start with these default values.
Bryce
(3,331 Views)
