Initializing Subsystems (Simulation Module)
I am building a simulation of a mechatronical system, using the Labview Simulation Module.
My model consists of many modules, that i want to represent by using Simulation Subsystems. The model is nested in that way, that Subsystems can contain subsystems.
Now, I am looking for a possibility to change the parameters of the modules, which are distributed in all the subsystems (e.g. a value for a gain), from a central point. I have thought about using an ini-file.
My question:
How can I, after having read the ini-file, get the parameters to the subsystems? Do you have any better ideas?
Thanks for your suggestions!
Thomas
(sorry for my bad English...)
(2,524 Views)
You could use the LabView global variables, or shared variables if you are using LabView Version 8:
Here you can find morew information:
http://zone.ni.com/devzone/devzone.nsf/webcategories/30FA588ECE8222FB86256A1F00760B21
(2,512 Views)
