Initiating a project file aborts Labview running Mac Parallels
I have been running Labview 8.2 on a Macbook using Parallels v2.0 with Windows XP for a couple of months. Worked great
others on the forum have had similar success.
I upgraded to Parallels 3.0. Labview loads. Vi's work, as soon as one loads or tries to create a project file,
Labview aborts.
I tried uninstalling and reinstalling Labview plus deleted Labview.ini.
No change in behavior.
Any ideas?
stan@engphys.com
Stan Cohen
Albuquerque, NM
(2,544 Views)
No problems on my system. Blacbook w/ Parallels 3.0 (just upgraded to 4560) and LV 8.2.1. I never ran 8.2 on parallels 3.0, so I don't know if that's a possibility. Also, I never enabled DirectX acceleration under the prefs; maybe you should look at that. I haven't had any negative interactions between XP apps and Parallels as far as I know, so I kinda doubt that that is the cause (other than an inability to suspend parallels after running a LabVIEW app - 3D activeX graph uses OpenGL and flakes it out, but I just leave my VM running all the time.)
Maybe check your hard drive for space. I started mine at 10GB, and ran out of space. Window's gets pretty unhappy without a nice buffer of drive space.
Chris
(2,540 Views)
