I attached a simplified version of my program with LabVIEW 8.2. I am trying to build an array inside my inner while loop whenever the case is true and then use it elsewhere in my outer while loop. I want to keep the array stored until a button is pushed to clear everything in the array and then be able to run the "test" again. I need to have both while loops for my actual application. I have tried using the first call function without much luck and also tried making a case structure in the inner while loop that reinitializes the array to zeros. If you have any ideas please let me know.
Dave
