Injector model
Is there any model available for disel Injectors?
(4,651 Views)
I did not find any good models when I worked on an injector project a while back. It appeared that the manufacturers wanted to sell their own drivers.  I made some mesurements and developed my own models.
Lynn
(4,629 Views)
Hi Lynn,
Thanks for your reply. I’d really appreciate if you could share your models with me elio.luethi@noser.com.
/Elio
(4,576 Views)
Is there any place besides the LabVIEW example finder, where I can find LabVIEW Models of any kind?
(4,575 Views)
The models I created are proprietary to my employer so I cannot share them.
They were fairly simple.  I measured the inductance and resistance and used those values for a starting point.  The inductance of course changes with the position of the armature. This can be difficult to measure: How do you apply a time varying voltage or current and measure them while having nominal DC applied and do it quickly enough to avoid overheating?  I was able to make estimates based on the shape of the waveforms while the injector was being energized.
Lynn
(4,568 Views)
