Inport/ Outport missing from my Labview
Hello! I need to use Inport/Outport for a school project, but they are missing from my Labview(probably because i don't have a parallel port at my computer). I can't use Visa because it's mandatory to work with Inport/Outport. How i can make to have those in my Labview? Thanks
(3,627 Views)
What version of LV are you using? What operating system.  I'm not sure where they used to be, but in my LV2009 they are in 7.x Functions / Advanced / Port I/O palette.
The actual files are in vi.lib\Platform\portaccess.llb
I noticed in the help for the function:
In Port Details
(Windows Vista) This VI does not appear on the Functions palette because it allows read/write access to any I/O port on the system, which is discouraged for security reasons on the Vista OS.
  • (Windows Vista) VI components install properly, but show up as "unsigned" in the Windows Defender log. This VI does execute properly.
  • (Windows Vista 64-bit) This VI returns error -4850.
Try using the search function on the palettes for In Port  (make sure you include the space.)
(3,609 Views)
