Input String and Number block
This is embarrassing.  I was just in a NI LabView presentation and they had an example VI that used a VI function that accepts a string and parses it based off of a token string.
So the example was…
If you had an input string of…
Value = 3
… and fed the VI function a token string of…
%s = %n
… the returned values from the block are a string and a numeric, “Value” and 3 respectfully.
Does anyone know where this VI function block is in the palates?
Thanks.
(4,427 Views)
Look for SCAN FROM STRING - row 2, column 0 in the STRING function palette.
Except the "%n" won't work.  If you're looking for a decimal number, use "%d".  Consult the help for other options.
Message Edited by CoastalMaineBird on 07-09-2009 03:34 PM
Steve Bird
Culverson.com
LinkedIn
(4,422 Views)
Hi Phillip,
"scan from string" in the string functions palette...
(4,420 Views)
Accepted by topic author PhilipJoeP
Scan From String (in the String palette).
EDIT: Guess everybody must be on a coffee break. Smiley Very Happy
Message Edited by smercurio_fc on 07-09-2009 03:34 PM
(4,417 Views)
