Input Trigger - Starting a VI after receiving signal
I would like to know if I can trigger a LabVIEW VI to start running after receiving a current signal. I have a NI 9208 current input module connected to a cRio-9074. I don't know what to add to my VI to make this work. Could someone help me with this, please? Thank you for your help!
Best Regards,
Daniel
(3,093 Views)
Hi Daniel,
Sounds like those 3 simple steps:
- read in signal in a loop
- end loop when "trigger condition" is met
- run your other VI…
Which of these is a problem to you?
(3,086 Views)
Thank you for your prompt response. My problem is that I don't know where to find these commands (I don't know the name of the function that I would pick from the functions palette). Could you help me with this? Thanks!
(3,067 Views)
Hi Daniel,
in this case I suggest to take the free beginner tutorials to learn LabVIEW and to handle the cRIO programming!
You may start here and here!
All you need to start is a (while) loop with a ScanEngine IONode inside to read your signal…
(3,045 Views)
