Input Voltage and Frequency to generate signal
I am new user of labview so do not know much details about it, I want to generate sine wave with varrying voltage and frequency.  first i want to load these values to creat sine wave (from excel file or using array) and then want to observe the characteristics of the signal with these varring V and f. is that possible , basically main idea is to observe power signal as from power grid
(2,530 Views)
There is a good shipping example that does that already.  It's a good place for you to learn some DAQmx and how to change a DAQ output on-the-fly.  Help > Find Examples...  Hardware In & Out > Analog Out > Voltage (non-regen) - Continuous Output.vi
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,507 Views)
