Input array listing possible test results to generate all test scenarios
See the lower half of the VI.
This will work for any number of columns, and any number of rows (but each column must have the same number of rows.)
Message 11 of 22
(1,659 Views)
Accepted by topic author dbrown78
I assume you are aware that your code is faulty, because e.g. row [A0,B2,C0] occurs at least twice in your output.
It is also a really bad idea to test with square arrays. Here's a scalable solution that works with any possible array dimensions (until you run out of memory, of course).
Note: If you want to cycle the leftmost element fastest, use two inner FOR loops. First create the array of indices then reverse the blue array before autoindexing on the loop where you index out the elements)
Message 12 of 22
(1,648 Views)
Ouch! This is either a FOR loop equivalent (If we are lucky! :)) or an infinite while loop (if we are unlucky and the equal comparison involving a DBL fails! :(<unlikely here, but still....> ).
Message 13 of 22
(1,642 Views)
I'm assuming that integers compared to an integer within a double will still work.
You're right, I should've made that a For Loop with the original x^y wired to the N terminal.
Message 14 of 22
(1,639 Views)
I agree that you are probably right but the exponentiation operates purely on DBL (notice the coercion dots) and I have no idea what's under the hood (Intel MKL?) and if it is guaranteed that all possible integer inputs really result in true integers in DBL representation. For example if they internally use logarithms etc., all bets are off. I haven't tested this. Probably safer to set the output configuration of "-1" to I32. 😄
Message 15 of 22
(1,634 Views)
This works... only problem is I have so many possibilities I keep getting memory errors... DOH!  I guess there will just be some cases I will not be testing, lol.
Thanks for your help everyone!  I really appreciate it!
Message 16 of 22
(1,608 Views)
Like I said, it gets exponential!
You may have to look at a Design of Experiments scenario where you vary multiple parameters between tests so you can reduce the number of tests.  Then the final analysis methods have means of attributing which degrees of freedom had more effect on the results and which did not.
Message 17 of 22
(1,591 Views)
Took a bit to figure it out but it was a really fun challenge, and I'm definitely gonna clean it up some and add it to my useful VI arsenal. This will work even if each attribute has a different number of values. Not sure if you will run into memory issues but it could maybe be optimized a bit more.
Config files would work nicely for attribute/value combinations because each section can be an attribute and each key can be a possible value, but you could get the "original array" easily enough from Excel, database, etc.
Hope this helps 😁
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 18 of 22
(1,577 Views)
Typically you would represent ragged arrays as 1D arrays of cluster where each cluster contains a 1D array of strings. Now each inner array can have a different size. This has the advantage that also empty strings can be a valid value to be shuffled. 😉
@FireFist-Redhawk wrote:
...and I'm definitely gonna clean it up some and add it to my useful VI arsenal.
Here' are some ideas. Arguably simpler. 😉 Currently it gives the same rows as yours, but in different order. That can be fixed, of course with a little more code.
Message 19 of 22
(1,539 Views)
Here's how that could look like.
Message 20 of 22
(1,527 Views)
