Input conditions
Hi everyone,
do someone know how do i make a programm that accepts no input that doesn't satisfy a condition ?
for example if i choose a voltage bigger than 2 Volt the program has to ignore it
(3,166 Views)
Accepted by topic author achouch
Hi achouch,
So you want to implement
IF condition not met THEN ignore input
I guess you will need a comparison function and a case structure…
(This is just one possible answer, but there are other options available. You might also limit the allowed input range of your control to reasonable values!)
(3,159 Views)
Thank you for your answer I wrote 'limit allowed input'  in google so i found that we can simply choose a range with clicking on 'properties' 😄
(3,147 Views)
