Input declaration
Hi, I'm new at LabView and I don't know exactly what the symbols in front of the INPUTS mean. There are some of these symbols that I have an idea. For example, 32INT may be an integer of 32 bits, DBL may be a double value (64 bits) and TF I think that might be a Boolean variable (1 bit). Where can I find those information? What does it mean? How wise are them? From what value to what value? Can I write a number of an order of 10^-9?
Thank you everybody!
(3,367 Views)
Accepted by topic author thalles
See page pages 72-74 from the manual below
http://www.ni.com/pdf/manuals/320999e.pdf
Yik
Kudos and Accepted as Solution are welcome!
(3,362 Views)
Thank you a lot!
(3,347 Views)
No problem!
(3,342 Views)
