Input queue compacted,
Software Labview DSc 6.1
OS - Windows 2000
Error Systems -  "Input queue Compacted" message comes and then Application gets terminated.
I had increated Input queue size to 6000 and still error is coming. Can anyone tell what should be ideal Input queue size vis a vis number of tags or frequency of tags which are getting updated.Can anyone tell what should be the ideal queue size when 4000 tags are written per second and also what should be typical RAM  requirement for that.
Any suggestion will be helpful
Regards
Uttam
(3,315 Views)
It would probably help if you posted your DSC config file. The Citadel functions in version 7 seem to be more reliable than version 6.1. I can't tell you about version 8. I run a couple thousand tags with 512Meg and 800Mhz processor on windows 2000. See the last file in this thread for one of my applications.
(3,310 Views)
