Input "Microsoft Paint" in Labview
HI,
  This is my first post in this forums,
How can i input "Microsoft Paint" in the labview and using it  ?
actually i know to use active X and input it ,
but i don't know how to use this method .
Thank you for your help
from
 0852
(5,385 Views)
use system exec fuction
我愿自己是个胡萝卜,可以自己自足啦!
(5,379 Views)
Paint is not an ActiveX object, so you cannot embed it into a front panel.
If you want to display images, you have to use the browser control, or a native LabVIEW picture control.
Wiebe.
(5,351 Views)
thanks all , which method that i can use ?
no any other method ?
what is system excec function ?
 thanks !!
(5,338 Views)
actually, i want to paint picture myself in labview....
is there any example or method ?
thanks
(5,333 Views)
Of course. Open LabVIEW, go to the Help menu and select "Find Examples...". This opens the Example Finder. Switch to the "Search" tab and enter "picture" and select the "pictures" item in the listbox. You'll find over a dozen examples.
(5,323 Views)
