Inputing Data into file
I am trying to input names and numeric data into a file.  I need append to the file and once I append to the file I also need to clear the prevoius info on the controls on the front  panel.  I have found a an example code that does this but but i am unsuccessful in modifing the code or reproducing it.
 my code and the example i have found are attached.
(3,067 Views)
And if you could post an image of this code, too, it would be helpful.
Thanks.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,058 Views)
Here is picture of my code and also the mathscript code I have attached
(3,044 Views)
Sorry te preious submission was a mistake, I will post my code later.
(3,039 Views)
