Inputting characters from a file
I would like to import characters from a certain file and have it appear in a table or chart in labview.  I used the 'read characters from file' icon and the data shows up in a chart. The characters that I am importing will be used to steps to a procedure to run and I wanted to be able to select a specific step.  How can I import a whole file into labview ,having it show up in a table or chart, and be able to individually select one option and use it as a step.
(2,906 Views)
I additon to my other question.....Can I use a while loop and have the counter select each character from the file individually and place each in its own table or chart.
(2,903 Views)
Here is a quick (and dirty) example of reading from a tab delimited file into a table and being able to select from the table. It is in LV7.1.1 Included is a simple example file.
P.M.
Message Edited by LV_Pro on 07-19-2005 01:23 PM
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,895 Views)
