Inquiry - What is your Modularity Index?
Hi All!
   I finally had my copy of "The Labview Style Book", and at pafe 13, I've found:
     Equation 1.1
     Modularity Index = (# user VIs   /    total # of nodes ) * 100
    The author recommends a MI above 3, in my projects I've found that usually I modularize a little bit more, above 4.....
   So, I'm just curious to know... what is your modularity index?  Check your projects, and post, it's easy! Just go on tools --> VI metrics....
   Reply massively, especially gurus.... Smiley Happy
graziano
Message 1 of 52
(9,198 Views)
Hi Graziano,
I get values from 4.1 to 5.
What's the meaning of this value? Can you give an abstract of this page/formula?
Message 2 of 52
(9,177 Views)
Hi GerdW,
   thanks for answering!
   This is just an index to see how much you modularize your code, I mean, if this index is too low (for example, 1000 nodes in a single VI), your code will probably be a mess, while if the index is too high, it means that you create many subVIs, even when it is not really necessary...
   Like in other engineering tasks, you have to tune heuristically this index, and what I'm interested in, here, is to see what's the trend.  Of course, this simple index doesn't tell too much, it's never easy to "measure" code, it's complexity, etc...
   Thanks again, and have a nice day!
graziano
Message 3 of 52
(9,163 Views)
Hi Graziano,
Is there a way to get those numbers if you don't have LV Pro?
Jim
LV 2020
Message 4 of 52
(9,117 Views)
I would think it would depend on how one programs.  For instance, if you have a "flat" vi versus something like an action engine.
LV 8.6 on Windoze XP
Message 5 of 52
(9,111 Views)
Hi!
   I was wrong on the link above, it is in
   tools --> advanced --> VI metrics...
   I don't know if this utility is included in basic packages.... I'll check!
    Thanks for interesting in this!
graziano
Message 6 of 52
(9,111 Views)
actually, from LV online help, it seems that this component is only available in "Professional" packages, and it seems to reside under tools --> Profile --> Vi metrics.
I was referring to LV 7.1
graziano
Message 7 of 52
(9,107 Views)
Hi Graziano,
It is definitely in the menu with the "Full (Hah!) Developers Suite".  I was wondering if anyone had developed a VI to do this before it was put into the Pro menu.
Jim
LV 2020
Message 8 of 52
(9,102 Views)
I meant to say that it is definitely NOT in it.
Jim
LV 2020
Message 9 of 52
(9,093 Views)
Hi Graziano
i found to have between 2.5 and 4.5 on my 6 latest projects.
in LV 8.2 it is under tools->profile->vi metrics
... And here's where I keep assorted lengths of wires...
Message 10 of 52
(9,089 Views)
