Insane Object error by copying from Edit List to the Documentation area
I placed a menu ring on the front panel.  I edited the list of menu selections for the menu ring.  When I copy the labels from the Edit Items list into the Documentation - Description area as shown (bold is copied portion):
Task Legend:
0 - Set Digital Port to HI
1 - Set Digital Port to Low
I get the following errors:
Insane backup object at FPHP+335A0 in "vi":{graphics} (0x80): cLStrObj (GNRC)
Insane backup object at FPHP+335A0 in "vi":{graphics} (0x2): cLStrObj (GNRC)
Insane backup object at FPHP+44 in "vi":{index graphics} (0x82): ObjHeapHdrExtension (GNRC)
Fatal Internal Error : "fpsane.cpp", line 319
LabVIEW version 7.0
You will lose any unsaved blah blah blah.
This only seems to occur if I copy two or more labels from the Edit List into the Description area without exiting the properties window.  I can repeatedly copy and paste a single label as long as I exit the properties window after every paste.
I tested this out with a new vi using only a menu ring on the front panel and the same problem occured after pasting two labels.  The only difference was the hex address value.
I'm not personally looking for resolution to this post as I've already found a workaround.  I just wanted to point out a minor bug I came across afer the knowledge base article stated to inform NI if it was a specific editing sequence that caused the fatal error.
(2,891 Views)
FYI, I was able to reproduce the problem in LabVIEW 7.0, but it doesn't seem to happen in 7.1 and later.
-D
(2,883 Views)
Thanks for contacting National Instruments.  We do know of this bug in LabVIEW 7.0 and appreciate you taking the time to tell us specific instructions to reproduce your error.  It is because of customers like ODRulz and Darren that we are able to improve the quality of our products.
For other users reading this post, there are a couple good KB links about what Insane objects are, and how to deal with them.
What Does An "Insane Object" Error Mean and What Should I Do?
Insane Object Errors When Adding or Removing Needles or Sliders in Properties Dialog Box
Hope this helps,
TheDillo
(2,868 Views)
