Insert Data to MySQL table
Hi.Need help. I already created the tables and column fields in MySQL. Now i have a 1D Array which contain similar field in the MySQL table. Example DR1in the array is similar wit DR1 column name in the SQL table.
I have another array which contains the data for the column.
help me cos there is an error wit the coding.
(4,225 Views)
Hi jeyanthi,
can you upload your vi and maybe your txt file? Where do you get the error?
Mike
(4,212 Views)
the attachment of vi and text file
(4,193 Views)
Hi jeyanthi,
you get the error because you connect a txt file to the database open function. You can only connect udl or dsn.
See the attachment please, it makes the same as your vi. Smiley Happy
Hope it helps.
Mike
(4,158 Views)
thk u :womanhappy:
(4,145 Views)
Mike,
What is udl and dsn?
Mathan
(4,138 Views)
