Insert Image into Front Panel Without Hiding Indicators
I am trying to insert a JPEG into the front panel in Labview.  I have successfully inserted the image, but  I want to add indicators and controls on top of it.  Whenever I try to do this, the indicators and controls are hidden by the image.
(4,274 Views)
Accepted by topic author Kim_Shrewsbury
Are you dropping the image in as a decoration, or loading it programmatically?
Are you aware that you can change the order of elements on the block diagram and front panel? Select an item (your image, for instance) and reorder it using the cunningly named 'Reorder' tools, highlighted below. Move Backward and Move to Back should help you out there.
CLA
(4,271 Views)
Select the picture and use the "Move to Back" option in the reorder tool (the last icon near the font and object controls).
EDIT:  Beat me to it AND he has pictures. Smiley Embarassed
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(4,270 Views)
Thank you.  This was a simple solution and saved me a lot of time!
(4,266 Views)
