Insert date/time in x-axis graph
Dear friends:
I would like to insert a array of the "date/time" in x-axis of graph.
How can I to do this?!
Thanks.
(3,429 Views)
Dear,
If you ll search for this problem u ll get endless solutions on this forum itself.
you can modify the properties of the X scale and select format tab. Then select absolute time . You will get the time as X-axis.
I could not open your vi becoz of higher version.
If this answers your question let me know.
Regards
CLAD
Using Labview 5.1,6.1,7.1.8.0
(3,421 Views)
Since the data doesn't appear to be regularly sampled. you would want to use an XY graph. Try the attached modification.
Message Edited by Dennis Knutson on 10-25-2006 02:20 PM
(3,420 Views)
Thanks for your attention. This modification is ok now.
Best regards.
(3,393 Views)
