Insert image file to word document using active X
I would like to insert an image into my word document (at the end). The image is saved as a bmp file and I'm using LV 8.2.1.
I would like to do this using Active X (without using report generation toolkit).
Any idea please ? 🙂 Thanks in advance.
J.
Message 1 of 11
(10,257 Views)
Accepted by topic author Julien_31
Hi J.
The method to use is Inline shapes (Add pictures). I have linked an example. You will have to configure it in order for it to be at the end of your document but that shouldn't be a problem for you.
Best Regards,
Message 2 of 11
(10,229 Views)
Thank you very much Charlotte. I've tried using this method (after having found another post about it on the forum, that was just a subVI) but it did't work. I guess I didn't link the functions properly...
Best,
J.
Message 3 of 11
(10,215 Views)
I would like to insert an png image into the header of my world document by using Active X. I don't know how to do it. Any idea?
Message 4 of 11
(9,941 Views)
http://msdn.microsoft.com/en-us/library/bb213595%28v=office.12%29.aspx explains how to do it in VBA for Word 2007
Message 5 of 11
(9,930 Views)
Thank you for the answer but i solved my problem.
Message 6 of 11
(9,903 Views)
Which function to use to place the image at the end of document. I am trying but not able to find that property.
Message 7 of 11
(9,829 Views)
many thanks for this code, I'm looking for something similar. My problem is that I have a folder with lot of pictures and I would like to insert into a word document them.
This VI is opening and inserting only one picture into word right? Is it possible to modify to more pictures which are in a same folder?
Thanks and best regards,
Gabor
Message 8 of 11
(6,977 Views)
Former Certified LabVIEW Developer (CLD)
Message 9 of 11
(6,955 Views)
Of course, you will need a list of files which can be accomplished with the "List Folder" function
Combine the two and you have your answer.
Good luck
Message 10 of 11
(6,950 Views)
