Insert item at array index using a for loop
Hi all,
I can't seem to figure out the tunnelling - if that is the issue - to insert items at a given index in an array.
I've attached my example, where I initialise an array of all 0s and add some arbitrary elements at some points. The output is a different array for each element I wanted to insert. I just wanted to add them all to the same array.
Does anyone know how to do this? Any help would be greatly appreciated.
(1,629 Views)
Accepted by topic author labViewComp
Your initialized array needs to be in a shift register.
You should also use "replace array subset" instead of "insert into array". (Insert will add a new element, shifting all upper elements up and growing the array in size)
(1,606 Views)
