Insert one array at the end of another....
Hello, I've spent half a day to efficiently solve this simple problem, but unsuccessfully... Maybe you can point to the right direction..
I've for loop that generates two arrays .. Each usually contains couple of hundred elements.... I want to stick these arrays to gather in long 2D array as in attached figure.
Message 1 of 12
(7,974 Views)
Just use Build Array.  You may need to use Transpose 2D Array to get the array the way you want it.
Message 2 of 12
(7,970 Views)
Accepted by topic author ku_ku
Like this? (assuming the two small arrays have the same lenght).
Message 3 of 12
(7,955 Views)
Why not just use Insert Into Array?
If you want things to be horizontal like you wrote, use the transpose array functions. If you don't mind using things rotated 90 deg, just leave them out.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 4 of 12
(7,926 Views)
Did you even look at his image and read the description? He want to sequentially fill an initialize large array with new data. The input arrays are also 1D, not 2D.
In your example, it would also be more typical to use "build array (concatenate mode)" instead of "insert into array" (middle).
Even simpler, use a FOR loop and avoid all these transpositions (bottom):
Still, this code does NOT solve the original problem of this thread!!!
Message 5 of 12
(7,909 Views)
Whoops. Yes I did, but I'll blame it on my glasses because I thought he had a 2-D array inside the FOR loop, as an example of what he was trying to combine. His initialization of a 2-D array at the front and an output array which had two copies of both input arrays (would have been adding a copy of the 2-D array inside, if it were there) seemed to support that conclusion, too.
Sorry, I'll be going back to the optometrist next week.
Cameron
Message 6 of 12
(7,883 Views)
Cameron,
Too many aromatic rings!
Lynn
Message 7 of 12
(7,871 Views)
I'm just wondering, why my VI gives an error.. Is it because of version 8.6 or ?
If I remove the first index it work fine.
Message 8 of 12
(7,827 Views)
You should only wire something to 1 of the index terminals (because you are putting an array into a 2D array) (had it been a single number into a 2D Array, you should have wired both index terminals)
If you wire to the first index terminal, it pops data into your 2D array row wise
if you use the second index terminal, it places it column wise
Message 9 of 12
(7,809 Views)
Since you are preallocating your array, I think you want to use Replace Array Subset instead of Insert Into Array.
Message 10 of 12
(7,807 Views)
