Insert or Replace column of string array
I am attempting to replace or insert a column of data into a string array.
Based on the header value of the incoming array, I would like to insert or replace into the existing array.  The two incoming arrays shown in the front panel is just for illustrative purposes.  Only one incoming array is present in the actual implementation of the code.
Any help will be greatly appreciated
(4,211 Views)
I'm confused.  What's your question?
Edit: I think I understand now.
Bill
CLD
(Mid-Level minion.)
(4,202 Views)
You can make a case statement that depends on the value of the header.
Bill
CLD
(Mid-Level minion.)
(4,199 Views)
Assuming that the headers are initially sorted and that the numbers are simple whole numbers a solution is easy. Here's one possibility.
If we are really dealing with integers, I probably would stick to a blue datatype.
(4,150 Views)
Accepted by topic author hiNI
I probably sleep better at night without orange. Here's one possible integer solution:
(Again assuming that the column headers are initially sorted, of course!)
(4,144 Views)
