Insert (really) a NEW ROW into Excel WKST
Hi everyone...
I had read some post about it but anyone has the answer that I'm looking for...
My project will have more than 2000 rows and 10 or 15 columns in a worksheet... I know how insert data in specific row/column but that isn't the answer to my problem.
Insert method as it applies to the Range object.
Inserts a cell or a range of cells into the worksheet or macro sheet and shifts other cells away to make space.
expression.Insert(Shift, CopyOrigin)
expression Required. An expression that returns a Range object.
Shift  Optional Variant. Specifies which way to shift the cells. Can be one of the following XlInsertShiftDirection constants: xlShiftToRight or xlShiftDown. If this argument is omitted, Microsoft Excel decides based on the shape of the range.
CopyOrigin  Optional Variant. The copy origin.
I dont know how to select the row to INSERT and SHIFT DOWN the rows.
I want the following:
ORIGINAL                                INSERTING ROW
ROW    DATA     ------->>>     ROW     DATA
745         one                            745          one
746        two                             746          "NEW INSERTED ROW"
747       three                            747         two
748        four                             748         three
I attached a "pic" about it. HELP I had had some headaches jus for this.
(3,800 Views)
Hi Ziccozzis
I’m very glad you use LabVIEW with ActiveX. This is an example about how insert a new row into an Excel worksheet. Tell me if you have any question.
Best Regards.
Coamín Cruz
AE México
(3,776 Views)
Hi Coamin...
I Couldn't see your VI because I'm using LV8.0
I've found the answer to INSERT A NEW ROW/COLUMN using only LV. I didn't use a macro from XL... I only use LV ActiveX.
I think it will be useful to everyone...
But... Coamin, I would like see your code. It can open my mind to new ideas.
Best regards.
"Change ROWS to COLUMNS to add a new COLUMN"
(3,757 Views)
Hi Ziccozzis
Great news!!
This is the VI in version 8.0.
Have a nice day.
Coamín Cruz
AE México
(3,743 Views)
