Insert slider dynamically into slide control
I've got a problem with a slide control. I want to realize a step control which can show several milestones.
The space between all these milestones should be coloured to be recognizable within one view.
So, I thought, the best solution would be a slide control.
BUT:
If you want to add a slider to the control your VI mustn't run. Because this isn't a dynamical property to add a slider.
But it's important for my application to visualize this.
Is there any other control able to do my task? Or have I to create a XControl?
And if I have to create a XControl how can I implement a new property?
I would be thankful for any help and thanks in advance.
Greets,
Joe
Message Edited by PatchProgram on 04-25-2006 07:35 AM
(5,420 Views)
SImply add as many sliders as you will possibly need, then you can hide the unused ones during runtime using property nodes.
(5,410 Views)
This is exactly what I want to do.
I have a pointer slide and I want to add or remove a pair of sliders by clicking a add- or remove-button.
I placed the slide on the front panel, added several sliders to this slide and created a property node of the slide. Now I don't find a property to make one slider invisible. I can only make the whole slide invisible.... 😞
How can I make a slider (not the slide) invisible?
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
(5,111 Views)
You can change the fill color to be transparent.
(5,100 Views)
I stil have no clue...
Doesn't refer the fill colour property to all sliders?
What color number is transparent?
Attached some pictures:
1. a clueless try
2. the slider properties
3. the slider
No clue what to do
Greetings Johannes
(5,088 Views)
The value for transparent is 16777216. In LabVIEW 8.2 I have the "color box constant" for this value.
Regards, Vt133
(5,074 Views)
To change the color of a particular slider, use a property node with two entries:
  1. active slider
  2. Slider color
For example, to change the second slider:
Wire the desired slider index to (1) and the desired color to (2). Use a colorbox diagram constant and select transparent.
(Also, feel free to support my related idea to simplify all this :))
(5,067 Views)
