Insert the same element into a 2D array of strings
I have an array of rows and 1 coulmn and I would like to put one element in all the specific places
For example lets say the column is 2 and the array of rows are 1,3,4    and Data is 122
so the array shoudl look like this
              Coulmn 1          2         3            4             5
Row 1                            122
Row 2
3                                    122
4                                    122
5
I have tried insert into array and Repalce Arrat Subset but still I couldn't do it
(2,794 Views)
You could autoindex on the array of rows on a FOR loop and replace the correct element at each iteration. Make sure to keep the array in a shift register.
There are many easy ways to do that, but since you did not show us any code, we cannot tell what you are doing wrong. Please show us what you got so far...
(2,786 Views)
Try this (remember that the first row or column is index 0, so modify as needed if you want to start with one.)
(The function is "replace array subset")
(2,772 Views)
