09-01-2010 09:01 AM
I have Requirements Gateway and Unit Test Framework installed on my system. However, I do NOT have a "Unit Test Framework Test" option under Project Management in Requirements Gateway. Therefore, I am not able to add a Unit Test or a Unit Test Report to my Requirements Gateway project.
Do I have to add the Unit Test Types to Requirements Gateway as a separate step?
Wes
09-01-2010
09:15 AM
- last edited on
06-22-2026
01:48 PM
by
Content Cleaner
Wes -
The LabVIEW Unit Test Framework installs an NI Requirements Gateway 1.1 example project to the <LabVIEW>\examples\Unit Test Framework\NI Requirements Gateway directory. The NI Requirements Gateway project file (.rqtf) stores the Unit Test Framework types in .types files within this same directory. If you would like your Unit Test Framework types to be available from all new NI Requirements Gateway projects:
You should now be able to access the Unit Test Framework types from any newly created Requirements Gateway project.
Please let me know if you still encounter any issues.
