Inserting a small graphics in a picture control
Does any one have an example code for inserting a small graphics/8 bit bmp file (15x15) in a relatively large (240x360) 8 bit jpeg image at known location in LabVIEW using Picture Control? Thanks in advance.
(2,615 Views)
To read an image file (BMP, JPG, PNG) and put it into a picture control you can use the OpenG function "draw image from file", and then use the picture control property "Zoom" to fit it correctly.
Here's an example :
You can get OpenG functions from here.
Hope this helps.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,595 Views)
Use the picture function "Draw Unflattened Pixmap"
(2,580 Views)
