07-21-2011 09:59 AM
I was wondering if it was possibe to use the Report Generation Toolkit to place an image into the cell of a table in a Word document?
Solved! Go to Solution.
07-25-2011 11:45 AM
Yes, you can do this by using the Word Edit Cell VI under Report Generation>>Word Specific>>Word Tables in your block diagram functions pallette. After creating a table, you can edit specific cells and send the file path of the image saved on your computer to that specific cell. I put together an example that I've attached here as well to help you out with this.
