Inserting formula in Excel cells, generating plots, adjusting the cell's text alignment (center, right, and left), and saving file using ActiveX
Since I don't have the Report Generation toolkit for Excel and I couldn't find more examples on how to do this
using ActiveX I need help in:
- How to insert a formula into Excel Cell(s)
- Selecting cells to insert plot(s) (polar and rectangular) from them.
- Adjusting the alignment of the text in the Cell(s).
- Saving an excel file to a directory
Thank you in a advance,
Rifaah
(3,120 Views)
Are you expecting someone to just hand the code to you without you attempting to do anything on your own?
(3,116 Views)
The attahced vi's are what I have so far and I get stuck in trying to got what I mentioned. I dont need the code but I can't figure out how to choose between the properties to know which one I actually need.
(3,110 Views)
Go to the NI Code Exchange, select Excel from the most popular search list and take a look at examples. This should help you getting started.
Ben64
(3,093 Views)
Ok I'll try both of these and see what happens,
Thanks for the help.
(3,078 Views)
