Inserting indicators into 3d models
Hi everyone, a great pleasure to belong to this community. Long time reader, but just registered to hopefully contribute, and because of the rise of this question that has drove me crazy.
Does anyone know if there´s a way to insert/locate a numerical indicator/label into a 3D Labview model?
If it can be done, does anyone know also if it´s possible to fix the indicator into certain coordinates, in order for being able to move around the 3D model, and have the indicator move around with the 3D model at the same time, following the same movements?
Thanks for all in advance, and have a great day : )
(3,551 Views)
I don't have any practical experience with the 3D picture control, but can't you simply create a text object and then update it with your current values? Converting a number to text is very easy using something like Format Into String.
___________________
Try to take over the world!
(3,528 Views)
Very interesting, I´ll give it a try. Many thanks : )
(3,497 Views)
Hi MS394
I'm really sorry to inform you that the controllers and indicators are not intended to be introduced into 3D image, the only thing they have is a small relief effect.
If you have another question or if I didn't answer the first one, write me.
Brenda
(3,424 Views)
