Instacal keeps losing my board information
I am using Meilhaus Elec software to set up and calibrate four boards that i am using to log data and control eqipment via a labview programm i have written. However, after i have set up the four boards (2x USB-TC, 1x USB-3104 and 1xUSB-1208F) using Instacal and then run the labview programme, the programme only runs for a few seconds then crashes. After the crash when I go back to Instacal some of the boards are missing or the board numbers have changed. Theni have to re-start the PC otherwise Instacal can no longer find the boards.
I have the four boards routed through a USB hub and then taking a single USB connection back to the PC. The PC is a HP with 2 GB RAM and a dual-core processor and when I run the labview programme without the boards attached it works fine.
Do you know of a reason why Instacal keeps losing the board information and connections?  Or is there some known conflict when using it with Labview that could explain the problems I am experiencing.
Any suggestions will be appreciated.
Regards
Trevor Morgan (Imperial College London).
(4,388 Views)
Accepted by topic author jopublic
It is possible to post your code? What did you mean by the program crashes?  Did  you received the error code “1-  Invalid board number” (ErrHdlng.VI from MCC)?   I have a LabVIEW program with four MCC boards: a USB-TC, a USB-3103, a USB-SSR24 and a USB-ERB24.  When I used a USB-HUB, sometime I lost the communication with a board, but after hours not after few seconds (I removed the USB-HUB).  Without the HUB the program runs for days.
Jean-Marc
(4,371 Views)
Thanks for your comments.
It seems that the PC or Instacal can't cope with 4 boards connected through a USB hub. On the advice of Melihaus Elec. i have limited my USB connections to 2 per port and this has solved the problem. The progamm nows runs without crashing.
It is also interesting to note that when i ran the programm on two older PC's it worked fine with all 4 boards connected to one port.
(4,353 Views)
